I actually got to get out last weekend and wheel my junk a bit. As a result I now have 2 tweaked fenders.
What's the best way you guys have found to get them straightened back out?
Did you tweak the sheetmetal or the arches?
The sheetmetal isn't a big deal, just a hammer, dolly, or a little heat.
The arches are thick and have a rolled lip on them, so straightening them is a bit harder as they aren't as forgiving. Particularly if they have creased.
Wow, that was fast!!!
No creases, I just tweaked the arches on a couple (rear driver and front passenger).
I'm with you on the sheetmetal, my question is on the thicker metal of the arches.
My arches had a couple of bends and I used a variety of things. C-clamps and wood blocks, a large hammer, a really big adjustable wrench, and welding type vise grips with the big wide jaws. Had to heat a spot or two as well.
I used a BFH and a lot of heat. My fender flares on the bed were pretty bad. They look almost perfect now. One of them ended up having half of it skimed with a slight coat of filler. I just couldn't get out all the little BFH dings. I am happy actually how well they turned out. I spent better part of a day working them over.
when you say heat are you talking oxy/ace torch or can I get it hot enough with a propane/MAP torch?
