OK so when I got the 68 a PO had swapped in a 63 Ford 352 and early Ford T98a from a big truck(7 x 1 3/8" input, wide bell housing, and 13" clutch/flywheel) the rest was all stock parts. Well I rebuilt the motor and was planning on keeping the 4 speed, until I got an almost free NV4500($80) a month ago. So now I've got a rebuilt 352, overhauled NV4500, and a NP202 t-case. I know I'll need to make a new cross members for the trany and t-case. I figure that if I keep the stock t-case in and mount up the front drive train I can get the center drive shaft zeroed out. This will give me the chance to get the correct drive shaft angles front and rear and also take any other alignment measurements off of the old unit. This is going on with the cab still on, so I need to get it right on the first try. Does this sound like a solid starting point?
Next I'll need to make a bracket off of the trany to hold the t-case and e-brake levers. What have you guys done for this? All I've got so far is either a custom PTO cover that integrates or is the bracket. Or use a small piece of braced angle off of two or three of the top cover bolts. I'll take any input, thanks.
