Results 1 to 10 of 35
Thread: finally bought an m715
Hybrid View
    Default finally bought an m715
    Hi All,
    I have been lurking on the site for a while and I recently bought a 68 m715 with a very tired but running 230 in it everything stock except michelin xls and marsh wheels. My brother has a good running 72 chev 427 truck motor that he is willing to let go for 300 bucks, it runs good no smoke or knocks. I will probably go sm 465 or 420. All I have right now is the engine alone with nothing else. I did some research on the site and correct me but it looks like I will need the following:
    Chev bell housing and sm465 from 70's or 80's pickup 2wd.
    big radiator from big block chevelle
    fab some spicergear motor mounts (or open to suggestions)
    what headers should I use? or are there any manifolds that will work
    12v alternator and brackets
    I will probably have to fab clutch linkage
    I live in the Rochester,ny area so if anyone has some of this stuff for sale let me know
    I'm not that good with wiring so if someone has a simple wiring diagram it would be greatly appreciated.
    Has any one put together a list of tips and part numbers for this swap?
    the more info the better thank you
    Jan 2007
    woodland ca
    for motor mounts you need to get the motor on a lift and see where you want it, and put on some hedars, or what ever you want to run becouse some of the hedars wont fit...
    what i did was get some 2 by 3 inch squair tube, and some plate, i had cut one end at a 45 angle, and the other at a 90... i had cut a plate, and drilled holes so the stock chevy clam shell style bushing/ mout fit right in, and welded that plate on the 45, then welded the other plate on the 90, then on to my frame... if i knew where the camera was i would take a pic for you.
    i have a 6.2 so i dont have headers so not shure if it would fit.... but nick had took some chevy mounts going all the way to the frame, and exstended them and plated them, and he has alot of room, and can fit anything becouse their exact same as a stock chevy truck...
    my idead works great so far, i can get all the measure ments if you want them... they look prety slick, and seem very strong, prety nice that i can use the stock chevy rubber as well.
    i also have a tranny mount done as well, save the scraps from cutting the angle, i had used all of it to make a tranny crosmember... i have a 465 with married 205... ill try and find that camera.
    my signature is sweet huh?
    Jan 2007
    woodland ca
    a easy way to do this is
    1. get some all thread and angle steel... you can get a jack stand under the tranny, and a cherry picker for the motor... get it roughly where you want it, and get the all thread.... cut some angle about a inch or two long, drill 2 holes....
    for the front of the motor what i did was hook up the all thread to the harmonic balencer and tack a plate to the frame, i was able to move it right or left, and then i cant rember exactly, but i welded a plate on the front of the frame, and was able to push or pull the motor...
    then for the tranny bolt a plat to the back of the tail housing, and take a plate to the frame. this will allow you to aligh up everything
    the only problem i had was adjusting the angle, but once your on level ground set up some jack stands, and let it sit on those while you do it, dont worrie to let it sit their for a day or two, take your time, i had thrown somany ideas... its all time and measurments
    sorry about the posts, im typing fast, and not paying attention....here ill try and find the camera and set everything how i had done it
    trust me, i tryed to put my motor in just by eyeball, and its harder that way then by measuring...for now cut everything out, stock mount in the garbage, their easy, i tortched mine off, just melt the weld and they will pop off... and the stock tranny mount goes, cut the crossmember mounts as well other wise your t-case will hit it. prety much gut all the stock mounts...
    hope that helps you out, let me know if you need anything....ill try and find some pics... i cant explane it that good... its like i know what to say but i cant type it haha.
    foodstamp thanks a lot, I appreciate the reply, any piictures of what you have done will be appreciated thanks.
    Hi Husky, welcome to the madness!
    I have swapped in a 396 Chevy into my 715. A few pics are listed below. They will fit pretty easily and without a lot of mods. As far as a parts list though, I have a legal pad full, so much too many to list here!
    Keep in mind a couple things about the 427 truck motor though:
    They are taller than the car engines.
    Intakes and such are not interchangeable, so you'll have to use the intake that comes with it. There are a few available, but they are pricey.
    Accessories and brackets for such are different than the car engines too.
    They also have very different pistons and ring setups and also are not interchangeable with the car versions. This makes them quite expensive to overhaul.
    The 427 and 366 are very similar motors. I am putting the 366 in mine. You may want to look into a deuce trans as they have an overdrive gear. The GOBS of torque and low gears will let you crawl over obsticles at very low rpms. If I had found a 427, thats the route I would have gone. You can get adapters for about $75 that will let you run "regular" intake manifolds, but the stock setup on these motors is fine for what I plan on doing(just getting a little more power).
  1. just bought my m715
    By larry cook in forum Open Discussion
    Last Post: March 10th, 2010, 12:24 PM
  2. robertcowan : I JUST BOUGHT PAUL CLEARYS M715-J10 CAB TRUCK
    Last Post: November 12th, 2009, 01:23 AM
  3. finally got my first m715 - let's talk modifications...
    By stepsidedan in forum Modified Tech
    Last Post: August 21st, 2008, 02:13 AM
  4. I just bought my M-715
    By viperman in forum Open Discussion
    Last Post: February 1st, 2008, 06:56 PM
