I have searched through the tech archives but still have somes questions ...
Suspension lift ....
Ok for the front ... springover and then reamed those knuckles to have the tie rod on top of them instead under , new longer draglink... but what about the brake lines .... do you need longer customs stainless lines .? What about driveline orientation ?? Does it need locking hub because of bad driveshaft angles ... need custom cv driveshaft in front ?
This was the easy part ....
Now for the rear ....
Since the axle in already in a springover situation, you have to flip the rear shackle from tension to compression. Then you will have to remove the oem front leaf mount and relocated them .... As far as i can understand you just have to flip the front leaf hanger upside down ... at least 3 holes will aligned ... and you must drill the fourth one. Then what about rear pinion angle ?? and brake lines issue ??
The job need to appear like if was come that way factory .. so maybe sometimes parts from other vehicle can retrofit on this one giving the look of oem parts .... or may have an NOS parts
I also read that if you want a good ride you can removed 2 leaves from the pack at each corner ... it will give less lift but better ride and flex ....
I'm looking to run 39½ Iroks that will see 99% street ... so i think this setup will be perfect, but i really need to know what is involved in parts doing that ... it will be a ONE shot week end mod.
Thanks a lot
