OK so I've flipped trough the "Modified tech" search for pictures and info to no avail. Here's what's up; I've got a number "76" steering box from an 86 Grand Wag. I was trying to test fit this box just to check things over. Well it seems that the nose of the box hits the front ladder of the frame. I could probably clearance either the box or the frame, but I'm not really interested in doing that unless I have to. I checked as many of the pictures as I could find on here and it seems that no one else has had this problem. It looks like I should have a 1/4"-1/2" of clearance between the frame and nose of the box. Is it just that the newer metric box is longer?
