Not going to say that it can't be done, but not quite as easy as just welding on a beadlock.
The rim is still a tube style rim. Doesn't hold air. So you would still have to run a tube. No biggie.
Second hurdle would be that the can isn't recessed in the center. By and adding a fixed ring to it you're making it very difficult to get a tire on. The recess in the center of a normal rim helps you elongate/oval the tire to get it over the bead. Obviously, I've no first hand experience with your described set up, but I can see it being a real pain in the azz to get a tire on if not completely impossible without damage to the tire.
With all that done, you're going to have some questionable edges in there for the tube to rub against. May or may not be a big problem.
