I wanting to put an electric fuel pump on my truck. Its still 24v. I know VPWs has got a kit for $98 bucks. Does any of yall know were I can get a whole kit cheaper. Thanks.
I forgot to ask in the first post. I heard you can orter these at the auto parts store. The carter solenoid type. What the prices range at the auto parts?
I found one at O'reillys 24 volt for $60. Alot cheaper then what VPW wanted.
Be careful not to under or oversize the pump. Perhaps someone else can recommend an appropriate level. For me, I have a 5psi pump feeding a 4 barrel holley that seems to work well.
This is the one I used:
http://saturnsurplus.com/miscpage/24fuelpump.htm
I have had it on for about three years and no problems. Worked great with both the stock 230 and the chevy 292 that I have in there now.
while this is about electric fuel pumps. my question is, is their a difference between a diesel pump and a gas pump?
my signature is sweet huh?
For the most part, a pump is a pump. Normally, gasoline parts are meant to be clamped to a hose while diesel parts are meant to be screwed into the fuel line. That makes a big difference in cost and quality of parts. Besides that though, just about any inline pump can be used for gas or diesel. Injection pumps are where the lubrication qualities of diesel are used by the way.
I have several inline electric fuel pumps intended for gasoline, we use around the shop and they pump a variety of liquids without any problems.
I have one that pumps parts washer fluid (mineral spirits) one that pumps ATF, and one that I use strictly for denatured alcohol when flushing brake systems. All of them are about 4-6 years old and so far have never failed. So I guess there really wouldn't be a problem using them for gas or diesel.
