what kind of oil are you guys using in the T98 tranny and the NP200 tranfer case?
The transmission, t-case and both axles take the same oil. The oil needs to meet GL-1 specs to satisfy the original specification for lubricant. GL-5 has now replaced GL-1 in the oil you find on the shelf.
The weight of the oil really depends on where you live. 80W-90, 90W-120 and just about any other combination you can find will all work as long as they are at least GL-1 rated.
I would suggest a trip to a tractor store such as TSC. Buy a 2-1/2 gallon bucket of oil along with the little pump that can be mounted on top of them. That will give you about two complete changes for the entire truck.
I would also suggest Permatex #2 gasket maker be smeared on both the drain and fill plug threads after you clean them real good.
thanks for the reply, I am going to change them all this weekend. I will keep the original oil that was put in it in 1967 if there is anybody that wants any authentic oil out there
