Results 1 to 10 of 14
Thread: Tornado Oil Grade
    Jun 2007
    Cornwall, ON, Canada
    Default Tornado Oil Grade
    I just recently purchased my first M715 and I want to change all the fluids. I want to confirm the right grade of engine oil to use. I looked at the Lubrication Manual on this site but I don't know what the military spec oil translates into. Would regular 10W30 be sufficient?
    Thanks for your help in advance...this website is a great resource for a newbie like me.
    New Jersey by Philadelphia
    I have used 10-40 as a minimum...and I always add one quart of Lucas Oil Stabilizer; that stuff is great!
    I have even used 20W-50 with good results.
    I am sure back in the day straight 30W was used...
    Being where you are, I would go with 10W-30 or lighter for winter and the same for your not so hot or long summers. Just install a Wix filter and keep it full.
    Jun 2007
    Thanks guys! I won't be driving this beauty in the winter at all and it will only see sunny days during the fairer months.
    I picked up a Napa Gold oil filter and air element yesterday with the part numbers I found here. I was a little shocked when I didn't find an air element in the cannister yesterday. DOH!
    Once I solve a little turn signal/brake/light wiring issue it will be getting a safety, appraisal, insured and then hopefully registered and plated. I can't wait to drive into town with this beast.
    Orignially in 1967 the army used regular 30W. Many members have gone with 10W-30 which seems to be a very good modern replacement.
    Zone holster maker
    Here in north-central Wisconsin, I run 5W30 in the winter and 10W30 in the summer...works great.
    Jun 2007
    Great 10W30 it is then! Any recommended brands? I run Mobil1 synthetic in my 2000 TJ because of the offroading I do.
    I imagine the regular stuff would be sufficient but should I add some Lucas Oil stuff to help the seals? Then engine smokes for a while when I start it up.
    Jun 2007
    Well I threw in some concentrated carburator cleaner, installed a new air filter, changed the oil (most of which dumped onto my garage floor) and installed a new oil filter.
    I went with 10W30 and what I notice is a lot of oil spattering out of the tailpipe. I don't know how much, if any was coming out before, but a little puddle was forming under the tailpipe and there was spatter on my garage wall.
    I'm thinking of draining a bit of the oil and adding some Lucas for the time being in hopes of helping the problem. Sounds like I might want to investigate the valve guide seals after reading another hot thread right now.
    Any other thoughts/suggestions? Thanks.
    BTW, are there any good repair manuals for the Tornado engine?
    the mil manual cover all the repairs for that engine, see the manuals link on the page header. if you have a puddle coming out of you tail pipe it must be condensation it gets colored by the inside of the pipes,(it forms and collects in the muffler if you look at a modern muffler it usually has a tiny hole drilled in the bottom back of it to let it out so it doesnt spray out the tailpipe) but for that much oil to get all the way to the tailpipe is almost impossible for a whole variety of reasons, most of the oil you see would be in the form of blue smoke. and yes the valve guide seals are always a major culprit on a engine as old as these the rubber in the seals just couldnt be any good after so much time in such an enviroment.
    68 M-715 MVPA #2710
    Agreed on the pipe stuff...condensate not oil.
  1. Hot Rod Tornado?
    By Team Nefarious in forum Open Discussion
    Last Post: April 14th, 2010, 06:12 PM
  2. Turbocharged 230 Tornado?
    By rpgdeity in forum Modified Tech
    Last Post: December 23rd, 2008, 03:51 PM
  3. 230 Tornado MPG
    By roscoe in forum Open Discussion
    Last Post: March 8th, 2008, 11:40 PM
  4. Tornado Temp?
    By 65Gladiator in forum Stock Tech Archives
    Last Post: January 24th, 2004, 07:16 PM
