Where can i find a good clutch. Finally got all the adjustment out of mine and it wont untrack.
a b lynn has them hes on e-bay just had one on there too but he has more also im sure someone here will post the napa number for them too
68 M-715 MVPA #2710
Clutch parts are available from civvy sources:
Heavy duty Clutch disk: Westling # RBP CD3271
Heavy duty Pressure plate: Westling # RBP CA1470
Throw out Bearing: Fed Mogul # BGS 1562
Rear main Seal: # JV734
This cluch disk will work too...more of a std duty:
K/M CD3387
I've got a flywheel for free if you will pay for the shipping. Let me know.
Whats the cost on a set up normally run. I got a heck of a deal on a kaiser and the dang clutch is out.
civy clutch discs are smaller than m715 discs.
The ones listed above are 10.5 inch, just like the factory M715 one.
I have replaced my clutch twice now...both replacement clutches are exactly the same diameter as stock...ony difference is that instead of being a 3 finger Borg and Beck type, I ended up with a diaphragm type...many finger...I compared them side by side before buying the replacement...no chances taken. That was the last part number listed above...but the earlier one for the clutch disk is the same diameter as well.
all civy 230 clutch disc,s i,ve removed are 1/2" smaller than a m715 disc & pressure plate.
I can absolutely verify that both of the above are exactly the same diameter as the stock M715 clutch disk. Many members have used these parts and none has ever reported an issue, including me.
Well i am still needing a clutch. Does anyone have the part # for the one at the napa house. OR where else can i get one and what is the part# thanks
