Results 1 to 3 of 3
Thread: I can't figure out...
    Default I can't figure out...
    I have noticed that titles appear at each persons name, like recruit or solder etc, what does it stand for and how is it applied? Also when searching members there is a column that is titled 'reputation' and its all little boxes that are either green or blue (i saw one that was red)agian what does it stand for and how is it rated?
    68 M-715 MVPA #2710
    Rank goes by the number of posts on the technical boards that members have...the more posts, the higher the rank...except mods and higher...they have fixed ranks.
    The reputation part deals with other members giving an "atta boy" to another member for a good post or such...or for giving the opposite. Green is where everyone starts, blue is higher and red is lower. If you click on the little folder with an X and a check mark on the upper right of the post box, you will start the process to add, or subtract, a point from someones reputation...you can leave a comment too.
    The reputation isnt really used all that much...for better or worse...
    Port Orchard, Wash.
    It will be now....
    -- Tim Taylor
  1. help i can't figure this out
    By barnaby82 in forum Stock Tech
    Last Post: January 3rd, 2008, 04:06 PM
