The water pump on Agengr's 230 was leaking and wobbled a bunch. We pulled it off last weekend. He has another one, but I don't think there is a good gasket to go along with the new pump.
I was just going to use silicone and bolt it up. Then I started thinking about the very tight clearance between the impellor and the timing cover.
Anybody done the water pump install without a gasket?
I figure we better be safe and make up a gasket unless somebody speaks up.
Thanks.
