Results 1 to 10 of 10
Thread: pto shaft, piece or one?
    Default pto shaft, piece or one?
    does the pto shaft to the winch have to be two peice to clear something? or can it be one piece. I remember reading a post a while back about someone looking for a shaft, and someone said just go get one made. so am wondering if a one piece can be done?
    Thanks
    Duane
    Stock is a two piece design if I remember correct. It has a bearing support that bolts in under the alt.
    the org is two piece , some of of them are one piece since the distance between the trans pto an winch never changes,however w/o a slip yoke they have to be made to exact size to fit properly.
    Without looking I don't think it will clear the frame if one piece.
    i meant to say in other vehs are one peice
    The shaft leaves the drivers side PTO with a u-joint connection and goes basically level to the front engine mount. It goes into a pillow block, has a u-joint and then the next section of the shaft goes toward the winch, where another u-joint is used to connect to the winch with the shear pin yoke.
    So, 3 u-joints, 2 sections of the shaft, pillow block or carrier bearing and a different end at each destination. Several set screws are used to hold some of the parts together.
    I took pic's of my pto so here they are
    As you can see, i don't have the shaft going from the winch to the yoke before the first mounting plate, but that should help you a lot
    Huntingtown,Md.
    It looks as if a one piece will work, I'll look closer.
    I know when I built my shaft I put too much angle on the U joint and get some knock out of it. Idle speed is ok but with RPM it will knock.
    I was wondering that as well yesterday when i was taking the pic's, i could get almost a clear shot to the winch, but the bracket was in the way.
    also after thinking about it, with everything else chopped up, that front shaft maybe cut in half, will go take a look after while.
  1. 503m715 : One piece gas filler
    By 503m715 in forum PseudoZone - Open Archive
    Last Post: November 12th, 2009, 04:55 AM
  2. Pto Shaft,
    By airborne in forum Open Discussion
    Last Post: February 23rd, 2008, 11:31 AM
  3. PTO Shaft
    By kaiser715 in forum Modified Tech
    Last Post: February 14th, 2008, 11:50 AM
