since the parts page is down does anyone know the aftermarket part num. for the front wheel seals?
Do you mean the axle grease seals? If so this is in the parts file pages:
The part numbers you require are as follows:
1.) Inner Bearing Oil/Grease Seal (National # 475384 x 54);
2.) Complete Knuckle Gasket/Seal Kit (Spicer # 706230X) which includes 12 x rear oil seal bolts, 2 x outer metal seal, felt gasket, rubber seal, and metal ring seal.
Try your local Napa first, then Border Parts
619/461-0171, then Motion Industries 619 or 858/565-0092.
Another option is AB Linn. He has seals for all 4 corners on E-Bay all the time at around $16.00 for the set.
just looking to repack front bearings
If you try buying one front seal at a NAPA or any place local to you, it will probably be $20+ for the one seal. That is why I mentioned AB Linn and all 4 seals for $16.00.
Now, if you just need the paper gasket on the outside of the hub for the splined hub plate. Just use rtv sealant.
When I installed my front disc brake kit, I replaced the seal that mounts to the hub. It was $47 from NAPA. Like previously stated, AB Linn has em MUCH cheaper. I didn't know before I bought it, but now I do.
