Agengr has his truck at my house so we can share the work on it. He bought a brand new M35A2 rear wiring harness. We put it on today. The rear was about 18" short of reaching both tail lights and the front of the harness ended just before the brake light switch. We had to put new fully insulated wires on both of his rear light buckets to replace the exposed aluminum and just made the passenger side about 24" long to get around that problem. We also had another front wiring harness from Alosix. Once we added the solid state blinker circuit, we needed 6 30" pieces to connect it with the rear harness. Not a problem and Packard fittings don't care how many times they are used.
If you are looking to rewire your truck, the M35A2 rear harness is a very cheap way to get all the wires and fittings you need brand new. It is not a direct plug and play type set up though. You will have to add a little here and there, but you can't buy the connectors by themselves for the price of the entire harness.
Something to think about.
