Results 1 to 5 of 5
Thread: cucv axle ?
    Default cucv axle ?
    Question for anyone that has done a cucv front axle swap into our trucks. I made new spring hangers so as to line up with the factory gm perches. I know our springs are narrower than theirs but has anybody welded in a shim to the side of the diff. housingso that the leaf spring is up against something solid. I don't know if it needs it but it does leave about a 1/4" of room between the inside of the spring and the diff.
    May 2004
    Anchorage, Alaska
    I would think that the locating pin thru the springs into the perch and the combined force from the ubolts would or should keep the springs from moving around on the perches. I think you would have far bigger problems if it breaks either the ubolts or shears off the locating pin than that 1/4" of gap...
    Huntingtown,Md.
    Pic's please. Front and rear. I was thinking of going this way.
    Once I finish i'll post some.
    Jan 2007
    China Lake Naval Base, SoCal
    The springs I just pulled off my donar CUCV are the exact same width. The perches will fit perfect on my set that I just welded on. See Saturday Play Time for pics of the spring mount work... I will be putting the axles back on in couple weeks... I'm away from the shop for awhile.
    Last edited by Binford; June 24th, 2007 at 12:57 AM. Reason: Added link for convenience
    Go Ahead, Make my day
  1. Cucv axle backspacing
    By robo in forum Modified Tech
    Last Post: March 19th, 2010, 09:21 AM
  2. cucv axle (again)
    By blairdes in forum Modified Tech
    Last Post: March 2nd, 2009, 11:23 AM
  3. Need input, CUCV axle question
    By ChalkOutline in forum Open Discussion
    Last Post: October 2nd, 2008, 11:43 PM
  4. CUCV Axle ?'s
    By Jay Dog in forum Modified Tech
    Last Post: January 7th, 2008, 05:09 PM
  5. CUCV Axle Swap
    By kalikraven in forum Modified Tech Archives
    Last Post: February 7th, 2004, 11:25 PM
