My truck came equiped with a bolt on turn signal switch box with lever and hazard pull out marked SIGNAL-STAT 900 SIGFLARE DOT QQC 76.
My questions are: (1) is this an original piece of equipment or an add on? (2) Is this 12 or 24 volt? (3) Is there some kind of fuse inside that should be changed to become 12 volt if it is 24?
At first I thought it looked pretty cheesy and the P.O. had grafted several wires onto the wad of electrical tape sticking out the side. Plus the bracketry that holds it onto the column looks cheap and flimsy...I'm going to disasemble it here in a few to see whats inside but if you guys have any info that I could use...thanks in advance. T
