Thread: ignition options?
    Default ignition options?
    Over the long weekend I finally got around to throwing in the Tornado I got from Tracy. What options do I have for ignition? My old engine, that ran when removed, has a Prestolite dist and fender mounted 12v coil. My main problem with it was I could never get the timing light to sync on the no.1 plugwire. It would sync on 2,4, & 5 only. I swapped the no.1 and no.2 wire, no help.
    The new engine has the mil ignitor with civvy wires and plugs. Pardon me if this is really stupid, but is there a 12v coil that will work in the ignitor?
    Is there an aftermarket all new electronic ignition that has been used on the 230?
    Thanks,
    Rob
    Springdale, Arkansas
    Hey Rob, glad that engine found a good home. It was running like a peach when I pulled it, hope it gives you the same service.
    The second link says Kalikraven had the stock dizzy converted to electronic and running with a 12v coil. PM sent.
    Tracy, Your truck was 24v when you pulled the engine wasn't it?
    Huntingtown,Md.
    The 'Ford' kit wouldn't fit in my 12vdc dist at all. Try the 'Pertronix' kit.
  1. Seat Options
    By Roy in forum Modified Tech
    Last Post: December 6th, 2009, 11:48 PM
  2. Mirror options
    By kaiser715 in forum Open Discussion
    Last Post: September 20th, 2008, 06:06 PM
  3. Rim options
    By V8-m715 in forum Modified Tech
    Last Post: August 18th, 2007, 02:39 AM
  4. Carb upgrade options?
    By Farmer_Jack_13 in forum Stock Tech
    Last Post: April 20th, 2007, 10:40 PM
  5. master cylinder options
    Last Post: April 12th, 2007, 09:41 AM
