Results 1 to 5 of 5
Thread: Suspension Question?
    Question Suspension Question?
    This is for you guys that are wheeling your trucks. To soften up the suspension are you using the stock spring packs and just removing some of the leaves or is it easier to convert to J-Truck springs? I am trying to get my plan down now so I don't waste time where it's not needed.
    Matthew
    Forget the J truck springs...they dont fit.
    Many have reported a big improvement from removing no more than 2 leaves per pack...usually the shortest and then skip one and then the next one.
    Cool, that will probobly be the way I go then, Thanks.
    Lone Pine, CA
    Don't expect miracles - I removed 2 leaves from each rear spring pack and didn't notice much difference. It's still a rough riding pig. Also, I only lost 3/4" in ride height from removing the two leaves - there is no more sag than with the stock configuration.
    I suggest keeping only the main leaf and experimenting with thinner secondary leaves of the same width to get what you're looking for.
    Chris
    I cut off some spring tails on my 725 and was pleased with the results. I was going for flex (I know, not in these things).
  1. FNG with question about power steering and suspension
    By snakeater in forum Modified Tech
    Last Post: January 6th, 2009, 11:39 PM
  2. Suspension Status?
    By Scoop03 in forum Open Discussion
    Last Post: February 11th, 2008, 08:46 AM
  3. air bag suspension
    By dodmort in forum Open Discussion
    Last Post: January 26th, 2008, 09:50 AM
  4. FYI stock suspension shocks
    By terryb in forum Stock Tech
    Last Post: April 2nd, 2007, 09:10 PM
  5. Coil Suspension
    By BulletSponge in forum Modified Tech
    Last Post: March 30th, 2007, 02:50 PM
