Results 1 to 7 of 7
Thread: 14 bolt rear discs
    Jan 2007
    Fort Smith, Arkansas
    Default 14 bolt rear discs
    Used the search feature and it helped quite a bit. I would like a pic of someone's setup though and maybe a little more detail of what it entails. I have a 75 chevy Dana 44 with 8 lug outers to use for parts. It seems there was some issue with locating the calipers due to spring interference. PaulC and Lee were discussing the mods, but I never really read a clear answer. Any Help?
    Jan 2007
    China Lake Naval Base, SoCal
    I'm in the middle of my conversion and am making a M715 version conversion manual with pics and drawings etc.... lots of sites explain different ways.
    Finding the parts that work and good deals is the hardest part. The cheapest brackets I found were from Shakerbuilt at $80.00. I was going to make a set of my own but found it easier to use someone elses. They have the hole size and spacing right and the spacers right for typical 3/4 ton Cheby discs and calipers.
    For pictures of how Shaker did his see the following site. I will post some soon.
    http://www.shakerbuilt.com/14_Bolt.html
    I'm cutting my spring perches off and moving them for the M715 width. I want the axle to look clean, and I like the thickness of the stock perches. There is plenty of room between the springs and Caliper brackets on my axle. It may be a different version axle.
    More to come....
    Go Ahead, Make my day
    Jan 2007
    I just found a cheaper set from JKW for $58.00
    http://jkwoffroad.com/offroadproducts.php
    good pictures of conversion here
    http://www.pavementsucks.com/showcase/jkwbrackets.php
    My favorite design is the DIY4X, I paid $70.00 plus shipping
    http://diy4x.com/brakes.htm
    Southern Indiana
    OK, since it finally looks like I am going to knuckle under and go with modern axles, is this a must-do mod? I have no problem with drums on the rear, IF they will clear the 715 springs.
    Jan 2007
    The drums from a 14 bolt will not clear the springs of the M715.... I hope I didn't confuse anyone... the disc break conversion of the 14 bolt will.
    Jan 2007
    No confusion, that's exactly what I was looking for.
    Anyone have a part number for a short 'flex' hose from the caliper to hard line that they've used?
    thanks,
    Jason
  1. Dana 70 6 lug rear discs
    By Swampthang in forum Modified Tech
    Last Post: May 15th, 2009, 12:03 PM
  2. Rear axle u-bolt size
    By Jester in forum Stock Tech
    Last Post: October 30th, 2008, 04:48 PM
  3. 14 Bolt FF Rear Axle Swap
    By BigBlockBurris in forum Modified Tech
    Last Post: January 13th, 2008, 09:54 AM
  4. Anyone running Ugly truckling front discs.
    Last Post: November 6th, 2007, 02:23 AM
  5. 14 Bolt rear
    By gonz in forum Modified Tech Archives
    Last Post: May 10th, 2004, 11:27 AM
