Results 1 to 3 of 3
Thread: Using a M726 master cylinder on a M715
    Default Using a M726 master cylinder on a M715
    The worn out rusted up master cylinder I had on my truck was removed and I have a brand new replacement, which I was told fit the M726, and was slightly different. The stock one on my truck had the main brake feed line coming out the bottom, this one is coming out the side. I have pre-bent lines all set to go, but don't mate up. Does anyone use this side-loading master cylinder with a tee adapter to meet up? What do you guys use?
    I will look on mine tonight maddawg but I think mine comes out the front. I replaced mine years ago with a lockheed master cyl I think. I will check and post back.
    I know thewre are both side and bottom exit masters of the stock type...I dont know the difference other than that but either bending the line a bit, if possible, adding in a piece with a coupler, or using some kind of tee would work.
    I think I would add a short piece of new line with a straight coupler and make a nice curve out of the extra on the way to the new termination point.
  1. Stock master cylinder
    By gimpyrobb in forum Stock Tech
    Last Post: June 5th, 2008, 09:33 AM
  2. Master Cylinder Swap
    By Chop Parlor in forum Modified Tech
    Last Post: June 1st, 2008, 06:53 PM
  3. master cylinder options
    Last Post: April 12th, 2007, 09:41 AM
  4. master cylinder Q.
    By kaiserkoski in forum Stock Tech Archives
    Last Post: April 27th, 2004, 09:40 PM
