Results 1 to 10 of 18
Thread: Brake T fitting....AGAIN!
    Springdale, Arkansas
    Question Brake T fitting....AGAIN!
    Hey was just looking over last weeks discussion on brake T fittings by Stranman and others.
    I was out trying to replace all my lines with stainless ones today and discovered that all my T fittings and connectors were missing from my pile of parts...Crap, dangit, nuts!
    I've sent some PM's to different ones about trying to find replacements but...
    (drumroll-please...) Is there some way to fabricate a T using modern/available components that will work? I'm using the vette m/c and hadn't planned on any proportioning valve either. My plan was to just hook up the fronts to the rear of the m/c and the backs to the front.
    Ughhh...things are exponentially more difficult when you don't know what you're doing to start with. hahahahaha
    3/16ths line? I see thi page has a part number and pic of a tee for that line size...at Pep Boys no less...must be other sizes:
    http://www.my427sc.com/Pages/Parts/Brakes.htm
    #10 on the page...part number is:
    43521
    Pic is linked at the very end of the line...the wheel cylinder icon.
    Here is a nice one for burly 3/8th inch line:
    http://shop.easternmarine.com/index....categoryID=156
    Says its a trailer part but since its just a Tee...whats the difference?
    Jon, you are a genuine wealth of knowledge, I'm glad we've got you on this site. Thank you.
    Me too, or there likely wouldn't be a site.
    Atlanta, Ga.
    I found THE perfect replacement for ours, including the brake pressure switch, at a motorcycle shop.
    It has 3 X 3/16's ports and a 1/8" NPT for the pressure switch. As I remember it was for a '54 Harley with a side-car. I had part numbers and links on the old site...
    I remember that....thanks for reminding me Herb!
    Searched the temp site an found that thread:
    http://m715zone.proboards102.com/ind...5639428&page=1
    Got the t-block on order from Drag Specialties, also did a search for a switch but could not find one. Does anyone make a hydraulicly actuated tailight switch?
    Old Fords had them, sorry I do'nt remember the years though.
    Heres some links:
    http://www.speedwaymotors.com/GmSear...itleDescr=True
    First item...
    http://store.summitracing.com/partde...5&autoview=sku
    Barrman and Porkchop used one from Napa but we lost the part number in the crash....
  1. need some advice for fitting winch bumper
    By Duane in forum Stock Tech
    Last Post: November 17th, 2009, 11:09 AM
  2. fisherman : Brake line pressure switch for brake lights.
  3. bluesman2a : IMPORTANT Brake Fitting info!!!
    By bluesman2a in forum PseudoZone - Open Archive
    Last Post: November 10th, 2009, 11:57 PM
  4. Fitting on the trailer
    By b-tyme in forum Stock Tech
    Last Post: June 9th, 2009, 10:02 PM
