I've got my vacuum wipers working. Is there an application for civvy wiper assemblies that will fit? Is there a # for the front crankshaft seal? Is there a good universal steering stabilizer available?
Not sure about Civvy, but here is this, Wipers. Whats wrong with your vacuum wipers? Thats one of the coolest things on the truck.
68 M-715
67 M-725
For the Crank seal....if you mean #29 in this pic:
Then the factory numbers are:
SEAL, FRONT, FILLER BLOCK
FSN:2805-110-1974
Reference Number:11657695
There is another seal that is behind the damper, a water excluder seal, unique to the mil engine I have been told. It is #8 in this image:
SEAL, DAMPER
Reference Number:11640881
It has no FSN of its own but is listed along with the damper, #7, as a set with these numbers:
DAMPER AND SEAL ASSEMBLY
FSN:3020-459-9745
Reference Number:11657108
On the wipers, I'm keeping the motors. I need complete wiper blade assemblies compatible with the OEM arms.
I'm confused on the front seal. Is there a single piece lip seal in the front cover that the rear of the balancer passes through?
#8 in the second pic sits between the timing cover and damper so as to keep water out of the timing cover when fordng...thus the "water excluder" name.
#29 in the first pic is behind the timing cover.
I think I missed what you really wanted....the timing cover seal:
#20 in this image:
SEAL,CRANKSHAFT,TIMING COVER
Reference Number:11640704
No FSN listed. Whether or not it interchanges with the civvy part, I dont know but due to the differences in the timing covers and cranks between the 2, I doubt it.
Item # 20 looks correct. Thanks Brute4c. Does anyone have a number for that seal like from C-R or National, or are dimensions available from a manual? Also, I'm still looking for wiper and stabilizer help.
There are no specs for that seal in the manuals...thats all I have on it unfortunately.
The steering stabilizer can be done like this:
http://www.m715zone.com/vb/view.php?...ing_stabilizer
The wiper blades...one of our members, jfnemt1ff1, posted this link to what he has done:
http://www.bigscaryjeep.com/BigScary...;20Wipers.html
Hattacks posted:
Hey I just picked up a new set of wipers. fit with no issue. All I had to do is pull the little pin from the old blades. and they fit with no issue at all. NAPA # 60-1033 Classic wiper blades
My website (www.bigscaryjeep.com) has a writeup about what wiper you can use with the stock wiper arm.
Thanks for the help folks. I'll get the wipers and stabilizer done right away. I guess I'll have to pull the dampener and look at the seal. I'll post any info I get.-TB
I put the civilian seal in mine, C/R #20702.
