Results 1 to 5 of 5
Thread: GM Dana 60 Question
    Merriam, Kansas
    Default GM Dana 60 Question
    I'm installing a GM Dana 60 in the front of my truck today. How far do you thread the two studs on the passenger side of the housing? I stopped when the stud installer started to slip and when I looked the coarse thread was flush with the housing. However the studs are sticking out quite aways; as in several inches.
    They do have to be long enough to account for a spring pack and the spring plate. Mine were flush to the coarse threads.
    **I heart Bump_r **
    Merriam, Kansas
    I've got the spring plate and springs attached and I have an area almost two inches long with no threads before I hit the threads for the nuts. Should I just make a spacer out of some DOM and call it good?
    No.
    Something is not right. You shouldn't have that much space. ?????? pics
    **I heart Bump_r **
    Merriam, Kansas
    No pics. But the studs are 5 inchs long. I think the studs and ubolts I have are actually for a truck with high lift aftermarket spring packs. I was planning on using the stock 2 spring pack but after replacing the studs with two 5/8 x 2 inch bolts and running the u bolt nuts all the way down guess what.... there is a good 3/8 inch gap between the spring and the axle pad since the spring plate bottoms out on the housing. So now I'm looking at replacing the stock 1400 lb. 2 leaf springs with the optional 1900 lb. 4 leaf pack which should help to hold the weight of the 6.2. I'm trying to use stock springs because I don't what to raise the height of the truck.
    After this the next thing will be steering as I can see it probably won't match up worth spit.
  1. M715 Dana 60 and normal Dana 60 ?
    By 93-12smoke in forum Modified Tech
    Last Post: November 6th, 2009, 08:26 PM
  2. Dana 70 swap
    By SouthernM715 in forum Modified Tech
    Last Post: November 7th, 2007, 11:10 PM
  3. Ran across a Dana 70 HD Saturday
    By Nuke_spicergear in forum Open Discussion Archives
    Last Post: March 24th, 2004, 07:52 AM
