Results 1 to 3 of 3
Thread: Clutch Adjusting Rod
    Oxford, Maryland
    Default Clutch Adjusting Rod
    How do you turn the adjusting rod? There's a nut at the bottom and a threaded part: do you grab the rod with visegrips and turn the rod? Something else?
    Oxford, Maryland
    Default Answer
    I'll answer my own question. I removed the adjusting rod today. At the lower end is a threaded tip. Mine was seized. A lot of PB Blaster and it finally loosened up. I think you could damage this end if you squeeze visegrips too tightly. Loosen the jam nut and adust up or down as needed. Should have at least 3/4 to an inch of free travel at the pedal and the bell crank arm the rod is attached to should be at a 49 degree angle to the frame. I cut a piece of cardboard I had marked with a protractor to use as a gauge. Put some anti-seize on the threads, put her all back together and everything is fine.
    Glad you got it without boogering anything up Bill. Thanks for the explain too.
  1. Adjusting Valves
    By kyken in forum Stock Tech
    Last Post: October 6th, 2009, 02:37 PM
  2. Clutch......
    By Rakes67 in forum Modified Tech
    Last Post: February 12th, 2009, 09:07 PM
  3. steering gear adjusting
    By george walker in forum Stock Tech
    Last Post: October 19th, 2007, 02:27 PM
  4. Adjusting an Autometer Fuel Guage
    By fng in forum Modified Tech
    Last Post: September 9th, 2007, 08:02 AM
  5. Carb adjusting
    By adk4x4 in forum Stock Tech
    Last Post: June 4th, 2007, 01:28 PM
