Results 1 to 9 of 9
Thread: Coil Suspension
    Default Coil Suspension
    Hmm in the many years that this site has been open...dont suppose anyone made an attempt at a coil suspension for these things...seems like flex would be greatly increased w/ 4 links. This is probably crazy but Im still a little tired and running on alot of caffeine.
    There is at least 1 that has 4 link...somewhere I have a pic but not a closeup of it or anything...more a flex shot.
    I have coiled one. I used Ford 1/2 ton buckets, and coils, with fabricated radius arms. It drove, and rode very good.
    Mar 2004
    northern Arizona
    Has anyone airbagged one? Using the main leaf as a locator?
    just finishing up the front end of our 725.
    Used a 1994 Dodge 2500 front clip (was a gasser, so D44).
    Lower links are the right lenght for the spring hangers. Just need to fab upper link mounts and TB mount.
    Used coil buckets from the 2500 frame (plasmed them off and cleaned them up). Seem to be going well so far. Still no engine yet, so I don't know how it drives
    Jason
    Cool, that's good information!
    Quote Originally Posted by alosix View Post
    Jason
    **I heart Bump_r **
    Here's a pic of the buckets.
    You can see the lower link on pass. Need to notch the pass side hanger so that the control arm can go up a little more. DS side is fine.
    Main thing I'm worried about is whether or not we got the buckets the right hieght. They're right about in spec if the engine and front clip weigh what I think they should.
    Jason
    That's pretty cool. Any plans to brace that bucket?
    **I heart Bump_r **
    I've thought about it. Its actually attached exactly how it was on the 2500 we took it from. The bends in the brace make it pretty stiff. Might put 2 gussets on each one at the top though.
  1. Suspension Status?
    By Scoop03 in forum Open Discussion
    Last Post: February 11th, 2008, 08:46 AM
  2. suspension setup ( mostly rear )
    By Kamikaze12volts in forum Modified Tech
    Last Post: February 3rd, 2008, 02:22 PM
  3. air bag suspension
    By dodmort in forum Open Discussion
    Last Post: January 26th, 2008, 09:50 AM
  4. Suspension Question?
    By Thew_077 in forum Modified Tech
    Last Post: May 19th, 2007, 11:47 AM
  5. FYI stock suspension shocks
    By terryb in forum Stock Tech
    Last Post: April 2nd, 2007, 09:10 PM
