Results 1 to 10 of 10
Thread: gas tanks swap
    Default gas tanks swap
    i have my motor/trans/tcase swap in and am working a few bugs out. i decided to change the stock gas tank out and came up with a good raplacement that others may be able to use. i used saddle tanks out of a 75 chevy step side truck. the tanks tucks in betwine the two cross members in the front half of the bed. i mounted them very high with brackets off my frame and they look very nice.
    at this time i only have one in place but when i get time i will mount the second and put the tank solecter switch on the dash. the finished product is two gas tanks with common parts and cheep. i will try to get pics when i get time if anyone is interested.
    M715,s..are a mans jeep...
    I'd like to see some pics of how you mounted it. Did you run the filler neck out of the stock location?
    no i ran the filler neck to the bottom of the fenderwell. i cut a small notch in it to make the filler higher then the inlet on the tank. it took a bit of work to get the tank in. i forgot to mention that i have a body lift if that maters.
    Port Orchard, Wash.
    So what is the capacity of each tank?
    -- Tim Taylor
    If I remember correctly , capacity should be 15 gallons each . Thats what was in my 76 .
    you are correct they are 15 gallon tanks. that is the only bad thing about it, you can only have 30 gallons under the truck but that is nothing a couple jerry cans cant fix.
    Jan 2007
    China Lake Naval Base, SoCal
    Please! I wanna do it too it.
    my printer is not working at the time but i will post pics when i can.
    i just finnished my motor/tran/tcase swap. i made my own motor mounts out of part of a stock chevy frame/motor mount, this let me use full length headers for a chevy truck. the motor is a 454 and it looks factory in the truck, with a body lift i didnt have to beat my firewall at all. i went with dual electric 10'' 3000 cfm fans and the stock radiator and so far all is well.
    i cut the factory xmember for the stock trany out and made my own for my 465 so i can run my 3'' pipe strait out from my headers all the way to my mufflers. i also put cut-outs at the header collector for the hell of it. the clutch linkage is all factory chevy.
    the xcase mounts are made so the 3'' pipe can run without a bend along side the np 202 with a p.t.o. also.
    other odds and ends are a msd box in the batt box with dual batteries, custom front bumper/warn winch, lights under hood, electric feul pump, tach, cigarett lighter, 12v output in the dash.
    Port Orchard, Wash.
    Is this the same truck you gave me a ride around the block in when I picked up those NTDs? It's come a long way, if so!
    -- Tim Taylor
    yes its the same truck, it also has power srteering now.
  1. bluesman2a : Let's talk tanks...
    By bluesman2a in forum PseudoZone - Open Archive
    Last Post: November 11th, 2009, 04:34 AM
  2. Gas tanks
    By Ronner in forum Modified Tech
    Last Post: October 15th, 2009, 10:13 AM
  3. Dual fuel tanks
    Last Post: May 14th, 2008, 11:11 AM
  4. NOS gas tanks...
    Last Post: November 11th, 2007, 07:04 PM
