Page 3 of 3 FirstFirst 123
Results 21 to 24 of 24
Thread: Did this ever get tested??? <- pertronix
  1. #21
    Run that by me again...what mod did you do?
    Glad its running!!
  2. #22
    The end of the flat spring on the points and the wire to the coil attaches via a screw to a little bracket. I removed that bracket. BTW, it was always running, it was just points rather electronic igintion...
  3. #23
    Gotcha...thanks. Keep us posted how it works...you may have the setup more of us want to emulate!
    I believe that wire is called the Primary wire as it is the one that brings voltage to the points.
    I am glad its running with it cause otherwise it sounded like you might have wasted the money on the unit...I hate finding out things dont work AFTER I spent a wad on it...
  4. #24
    Oxford, Maryland
    Default Minor Modification
    I had to make the mod too. A little Dremel Tool action took care of it. Mine has been running for 6 months regularly and I have no complaints.
  1. Tested my winch today
    By chicklin in forum Open Discussion
    Last Post: February 9th, 2009, 01:39 PM
  2. Pertronix Electronic Ignition for Civvie Distributor
    By bdial in forum Stock Tech Archives
    Last Post: May 3rd, 2004, 06:54 PM
