Page 1 of 7 1234567 LastLast
Results 1 to 10 of 66
Thread: Brake Shoes
    Winona, MN.
    Default Brake Shoes
    Anybody know a civvy part # for brake shoes?
    There is a way to adapt a civilian shoe....this is a repost from WetCJ:
    Got my truck driveable just weeks before the 04 FE but it needed brakes. Had read about and knew that Joe/IA was using the "#60" brake shoes. MikeG (who I work with) convinced the local O'Reillys to sell them to us at about $35 since we'd be buying several sets between my truck and his fleet. Required different upper springs also, Raybestos #H122 is what we used.
    I installed the new shoes with new wheel cylinders(from ABLinn) on the rear first. Got the wife to come down and help me bleed it. After about a half an hour she was tired and I was ed, could not get a decent pedal (should mention that I had previously installed a new 1970 Impala, drum/ drum, dual 1" master cyl. so I knew that wasn't an issue). Tried adjusting the brakes up tighter and found that it didn't seem to adjust properly. I always adjust them out tight then back them off the same number of "clicks" on both sides and something just didn't feel right in that process. Took a drum back off the next night and after staring at it for a while decided that the position of the anchor pin at the top of the backing plate didn't allow the shoes to center properly, it tried to position them too high in the drum.
    Since the shoes looked identical to the originals other than the top and a minor difference in the adjuster notch depth (which the adjuster could compensate for) I decided to modify them.
    I made this jig
    Original shoe in jig
    Unmodified #60 shoe
    Cutting the shoe
    Cut, just clean up with a file
    This bump on the bottom of the shoe needs to be ground flat also (insides only) to work with the M715 backing plate, don't try hammering flat, shoe will crack (voice of experience)
    Installed
    After doing both axles this way they adjusted properly, bled properly (wife was happier) and worked good with very little pedal travel.
    Note- I did mine this way because I liked the idea of locally available parts and they were cheaper than original shoes at that time which may not be true anymore.
    Jun 2007
    Cornwall, ON, Canada
    I just bought some similar Chevy drum shoes made by Satisfied brake here in town. They look very similar to the ones in the above photos. I was wondering if anybody has tried running them without cutting off the top portion. The reason why I ask is they seem to fit up nicely against the round center top pin IF you pull off the trapezoid spacer/adapter.
    Again, I have no idea if they would work and don't know what the stock Chevy drum setup looks like.
    Finally, half of the new shoes are slightly thicker then the other half. I was thinking of replacing the most worn shoe on each drum with the thicker of the new shoe...sound good to you all?
    Thanks for your help again guys.
    They didn't fit well against the round pin at the top when I tried that myself. I still had to cut the top portion of the shoe off to make them work.
    They look like they would, but, no.
    Montreal Canada
    James They will fit but won't work..
    I'm on vacation now give me a shout I can give you a hand this week.
    Let us not forget the arrow on the trap block must point forward according to the quirk manual. I just finished my re-cyl job and then found out I had 50% wrong!!
    Red face I'll have to check that on mine!
    Quote Originally Posted by adk4x4 View Post
    What are the odds of that happening?!
    Oh, wait a minute......
    -- Tim Taylor
    Jester Guest
    Default Part number?
    What is the actual NAPA part number for the shoes and the springs? Getting tired of the "what vehicle is this off" response from the parts counter.
    Jester Guest
    Can anyone confirm that the vehicle they fit is a 94 chevy K3500 4WD SRW?
    Part number I get from Autozone and Part America is 451. Picture appears to be what is shown above.
    13 x 2-1/2" shoe
    txs
    The part number I used is #60 or TS60 NAPA. Then you need the return springs which are United/NAPA #81233
    The shoes were $60.00 for the set and the springs were $10.00 back in April of this year.
  1. Brake shoes for dummies
    By fng in forum Stock Tech
    Last Post: July 27th, 2014, 02:07 PM
  2. oilcan : modified modern brake shoes for stock axles
    By oilcan in forum PseudoZone - Open Archive
    Last Post: November 11th, 2009, 03:06 AM
  3. Front brake shoes wet...
    Last Post: August 17th, 2009, 09:23 PM
  4. wheel cyl and brake shoes need
    By angler in forum Modified Tech
    Last Post: May 21st, 2007, 11:07 PM
Tags for this Thread
Copyright 1998-2022
