Hey you guys, Over2land needs a tie-rod end... you guys have a NAPA #?
QUICK!
Dave Druck
QUICK!
Dave Druck
adventureduo.com
Search here turned up nothing, but I found this on the PseudoZone (pretty quiet over there!)
http://m715zone.proboards102.com/ind...6141353&page=1
That should have what Jpete needs.
BTW, why are you doing his bidding? Lose a bet?
Good luck....
-- Tim Taylor
Timmah! I was stressed... after popping the cap off one of mine today trying to grease it. Hand held grease gun, pumped some grease in, no problem... then it got harder. I kept pumping, and pretty soon the peice that the zerk fitting was in seperated from the tie rod end itself. I called a shop owned by friends of the family and he strongly suggested replacing it.
In anticipation of search working on this board, here's the numbers I ended up with:
Moog PNs ES235L and ES235R
Napa PNs 269-2052 and 269-2051 If the Napa parts are in the correct boxes, the 2051 is the left hand thread one, while 2052 is the right hand thread.
Both stores made the comment that they've rarely seen anything with that low of a (selling/demand) score. I don't remember what they called it exactly, but basically if they sold any less of them, they wouldn't stock them even in the warehouses.
FWIW, if you had a 715 in Anchorage Alaska, and needed a set, you'd be fine. Both Carquest and Napa have them there.
Thanks for the search Tim.
