Results 1 to 10 of 15
Thread: Heavy weight m725
    Default Heavy weight m725
    I need to go to O.K. and get a m725 I bought can anyone guess the weight? my guess is 6000lbs. Am I to high?
    M725 curb weight is 6400#.
    I was thinking a little more than that, maybe 8,000 but not sure. I used a bumper pull 20' flatbed car hauler trailer and a CJ5 to bring it 90 miles. All went good at 40mph. FYI don't use a little jeep unless that is the only vehicle at the time. IA good 3/4 or 1 ton will pull it really easy as long as your trailer has brakes.
    i put mine on a nearby scale it was right around 8000#.i couldn't believe it was that heavy,my 715 was only 5500#
    I belive it should have the weight on the data plate on the dash, empty and loaded.My M725 Weights 6,420.
    Jan 2007
    west central wisconsin
    6400 lbs , TM 2320-244-20 pg 10
    Quote Originally Posted by sermis View Post
    That is scary!!!!!!!!!!!!!!!
    parsons Kansas
    I had mine delivered on a flat bed truck and not sure of the actual weight but the driver said it was one of the heaviest things hes hauled.
    I had mine at 6420 with a 1/2 tank of gas. I hauled one of mine back from Iowa to northern Michigan 20 car trailer 1/2 ton p/u with trailer brakes no promlem.
    John
    Thanks guys I have a Grand Cherokee with the 4.7 v8 I guess it can pull a 6000lb load on a trailer but I think I will take the half ton chevy(it's a loaner) unless someone is driving west with a empty trailer I'll pay the gas.
  1. m-725 top heavy? any trail experience?
    By KYSAR725 in forum Modified Tech
    Last Post: July 18th, 2011, 07:54 PM
  2. M725 max weight ???
    By Jim Hunter in forum Stock Tech
    Last Post: November 19th, 2009, 11:40 PM
  3. how heavy is you 715
    By jpsnblood in forum Open Discussion
    Last Post: May 2nd, 2009, 04:22 PM
  4. need hauler 715 heavy
    By johnny rezny in forum Open Discussion
    Last Post: February 14th, 2008, 02:38 PM
