Results 1 to 10 of 14
Thread: Modifying stock flasher system
    Escondido, CA
    Default Modifying stock flasher system
    Allright, not heavily modifying, but I need to add a circuit breaker.
    My '68 has the original solid state flasher and turn signal switch. It worked beautifully when I first got the truck running, but first I lost my directionals and then I lost my brake lights. Brake light switch has power in and out of it, so that's fine. I pulled the turn signal switch that mounts to the steering column apart and it is fried. The nylon was melted and there were black scorch marks, etc.
    I have a replacement switch ordered. When it shows up I want to put a 20 or 30 amp circuit breaker somewhere in the system to prevent this from happening again. I was just thinking I'd splice the breaker into the power wire to the switch (A/460-461).
    The question is: will 20-amp be okay or would I need 30? Will splicing into the A/460-461 help keep the flasher from frying in any way or just the switch? If there's one power wire I could put the breaker on to safeguard the system I'd rather just put the one in there.
    Anyone know? I need to get this sucker ready for our OD trip and TDS and I'd hate to be using hand signals the whole time.
    There is a circuit breaker in the 3 lever light switch...you didnt mention it so I wonder if either:
    Someone rewired and got rid of it...
    Its there, but malfunctioning.
    The power into the whole lighting system is on the wire that runs to the F pin on the cannon plug that connects to the back of the 3 lever light switch. If you take the cannon plug off the back of the 3 lever switch, look real close at the inside of the plug and you will see the letters.
    The primary power distribution wiring looks like this:
    If you follow the big wire from the alternator toward the foot starter switch and find the block on that wire that is the factory splice...the smallest wire from that splice will go through the firewall and split at another splice. The middle wire on the opposite end of the splice from the wire that you followed to get to the splice is the one you want.
    Short....you should already have the proper size circuit breaker in the 3 lever switch....but something is wrong to make the problem you have...I'd bet the 3 lever switch is bad.
    parsons Kansas
    it seems pretty common for the switches to go out as I think someof it has to do with construction quality and 24 volts but I might be wrong too. I had a brand new headlight switch go out in the deuce on me in texas shortly after putting it in then used the one out of my 725 to get me home without a problem. same with the turn lever in the 725. ????????????
    Escondido, CA
    Jon, that's perfect! Thanks, man. You saved me some time tracing wires and scratching my head. I hate electrical. I'd rather be welding or spinning wrenches.
    Yes, my electrical system has been hacked by previous owners and no, there is currently no fuse or breaker anywhere to be found in the truck. So adding that breaker to the F pin on the cannon plug will safeguard the whole lighting system? Cool. That'll let me rest a little easier behind the wheel.
    Now the only $64 question - should I run a 20- or 30-amp breaker?
    Yep on pin F...that will safeguard the whole lighting system!
    Dont know on the breaker size BUT....
    Since the stock alternator is 60 amp, I would think the 20 amp would be enough...hate to be wrong though...
    Maybe someone will chime in who knows better....lets see...at once, you can run:
    High beams, brake lights, parking lights, 4 way flashers and dash lights....if no other lights have been added to the load....
    Escondido, CA
    Yeah, aside from my 350's HEI there's nothing electrical in the truck besides the lighting system. And even that's not all there.
    I'll put the 20-amp in and throw a 30-amp in the glove box just in case. Thanks again.
    Brute4c,
    Thanks for pointing to that page. I had not seen the addition to the end of the wiring page but of course I don't look every day.
    I hope it helps somebody someday.
    It already has...and will again!!!
    I miss read your post I thought you were saying you had the old style switch. sorry.
    Zone holster maker
  1. Solid State Flasher Box Test
    Last Post: August 2nd, 2011, 09:58 AM
  2. Flasher unit
    By berkahna in forum Stock Tech
    Last Post: December 7th, 2009, 12:22 PM
  3. Stock brake system?
    By vacca rabite in forum Stock Tech
    Last Post: September 23rd, 2008, 01:14 PM
  4. Socket for turn signal flasher
    By bdial in forum Stock Tech Archives
    Last Post: May 4th, 2004, 12:48 PM
  5. 230 stock exhaust system
    By teking in forum Stock Tech Archives
    Last Post: January 10th, 2004, 08:46 PM
