Thread: Rear brake drums, should I turn em
    Washington State
    Default Rear brake drums, should I turn em
    Pulled off my rear brakes to install new backing plates with the Ford wheel cylinders, loaded with new brake shoes. Thanks Dan, I'll be installing new bearing seal, packing and checking the bearings. Will replace bearings if need be. Should I turn the drums? They are not blued and appear to have never been overheated. The current shoes are about 80 to 90 % and the current stock wheel cylinders look moist, not leaking. I am going to clean up the drums and paint, should I turn them before installing or not worry about. Let me know your ideas. Thanks Fisherman
    KINGSPORT, TN.
    i hope you marked the drums so they go back on exactly where they came off. and for turnning them, if there not groved from the rivets clean em and put em back on.
    Northern Colorado
    If the drums are smooth and not scored, I would NOT have them turned. You want them to last as long as possible!
    Hit em with some brake cleaner, dry, and install.
    Washington State
    I will put them back on the side they came from, someone else could have mixed them up easy though, it was a fire truck. Why do they need to go back exaclty where I took them off from???
    Covington, (the other) LA
    Cause the drums are machined for the hubs on which they are mounted.
    The tolerances are not close enough to make them truly "interchangeable parts". (Eli Whitney is whirling dervishly in his grave)
    If you install them on the wrong hub, or even rotate them one position on the "right" hub, they can cause excessive drum run-out, poor brake performance or brake shoe life, noise, vibration, etc. You get the idea.
    So - mark them before removal. If it's too late for that, try to keep them on the hub they started on. Try all three positions for the best fit. If you don't know which is which, bummer.
    KINGSPORT, TN.
    better listen to twodogs todd.
    bob
  1. kamokaiser : turning brake drums
    Last Post: December 15th, 2009, 07:55 PM
  2. Front and rear turn signals
    Last Post: November 18th, 2008, 11:07 PM
  3. Brake lights and turn signals
    By vacca rabite in forum Modified Tech
    Last Post: May 31st, 2008, 02:44 AM
  4. rear brake lock up
    Last Post: April 14th, 2008, 07:16 AM
  5. Stock specs for stock axle, wheel, brake drums & tires
    Last Post: May 31st, 2007, 09:46 AM
