Results 1 to 1 of 1
Thread: Parking brake setting
    Oct 2023
    Southeastern Kentucky
    Default Parking brake setting
    I?m setting the parking brake and can?t remember so I have 2 questions: First, is the feeler gauge 10 thousands or 15 between the drum and the band? Second, is the correct order to tighten the band on the drum so the feeler gauge can just barely be removed then adjust the linkage so the brake handle in the cab is fully engaged with 4 clicks?
    Set the side bolt clearance. Then the 2 ends. That should get your so only the nut that falls into the slot on the band and takes a 3/4” wrench needs to be adjusted to where you want the handle to grab at.
