Results 1 to 6 of 6
Thread: Diesel engine swap
    Feb 2007
    middle Tennessee
    Default Diesel engine swap
    My old M715 has a tired Tornado in it. The truck has been sitting in the shed for 5 years, waiting for a engine swap.
    Awhile back my Uncle called me up needing some help moving some trucks from a friend that had passed away. He had 3 old furniture moving vans that his widow just wanted gone. My uncle was just going to haul them away for scrap, but there was one that caught my eye, a 1988 Isuzu NPR diesel. Come to find out the NPR used a Isuzu 4bd1t engine, same displacement as a Cummins 4bt and similar power output. That got me to thinking about a engine for the M715. The only downside to these engines in this application is the clutch housing, it's a weird Japanese pattern. There are some 4bd1t out there with a SAE flywheel housing used in industrial and construction applications, but they are kind of rare and expensive when you find one. The trans in the NPR is a 5 speed non-OD trans with a cable shift, so I didn't want to use that.
    I had a couple of Spicer 3053a lying around from a couple of duces I parted out, so I went to work trying to make the Spicer trans fit. Finally got the engine and trans coupled together over the weekend. What I ended up doing is taking one factory deuce adapter ring and drilled it out to the Isuzu pattern, bolted it up and dowelled it in place. Then I took a second deuce adaptor, bolted and dowelled it to the first ring, this gave me the exact same space from the trans bellhousing face to the flywheel as the deuce. I then redrilled the Isuzu flywheel to accept a deuce pressure plate. After that I had to make a custom pilot bushing, 40mm OD to fit the Isuzu crankshaft and 3/4" ID to fit the Spicer input shaft.
    Here is a pic of the results, now to see if I can stuff this combo into the M715.
    67-m715
    71-m35a2
    Nov 2009
    Greenwood, Indiana
    I like the idea on this on. I say, go for it
    Thanks, George
    Joshua 24:15
    I love the ingenuity getting this together. How hard is it to get the Isuzu parts?
    Come and take it
    The cesspool of WA state
    Wow! Very cool adapting! Following..
    Liz, covid, murdered 10/19/21
    Sep 2010
    Middleville, mi.
    I'm liking it too. Following as well.
    Nice job. The Isuzu 4bd1t have the turbo on the left side so if you're running stock or right hand drop front axle you have lots of room for exhaust. I've also heard they don't vibrate as much as a 4bt. Looking forward to seeing it in the M715 engine bay.
    Feb 2007
    middle Tennessee
    Quote Originally Posted by gonz View Post
    Doing my research, everything is available through a Isuzu dealer or there are lots of aftermarket. Worldwide, it’s a popular engine. Only thing I?ve needed so far is a rear main and I got it at the local NAPA.
    67-m715
    71-m35a2
