Results 1 to 3 of 3
Thread: 12v DC CB radio, what would be the easiest way to set one up?
    Default 12v DC CB radio, what would be the easiest way to set one up?
    Hi, I'm a new member but longtime reader of the forum. I might be finally getting an M715 soon and its a dream of mine to have a CB radio rigged up. The vehicle I'd be getting still has the 24v system, so I'd need some sort of converter I suppose. I should mention I'm by no means an electrician. Has anyone dealt with this? Thanks a lot!
    These are the best dc to dc converters I know of...you have to check them to see which ones will take the 24 and convert to 12...they are there. High quality, high efficiency.
    https://samlexamerica.com/product-ca...e-converters/#
    This one for example will take your 24 volts and output 12 volts at 8 amps...not sure how much you need...
    https://samlexamerica.com/products/f...-idc-100b-12/#
    Oct 2014
    SCOTTSDALE, AZ
    A CB requires only a couple amps. One of the buck switching regulators on Amazon would do a fine job for just a few bucks.
    Here's an example:
    https://www.amazon.com/EPBOWPT-Conve...72&sr=8-3&th=1
    OR, you could have a full blown dual system, with either two 12V alternators in series (as in my M-715), of a modified center tapped 24V alternator. If you are interested in this, I will post the paper I wrote on the subject.
