Results 1 to 5 of 5
Thread: LS Engine to SM465 and Divorced NP205
    Jan 2022
    Black Hills, South Dakota
    Default LS Engine to SM465 and Divorced NP205
    Reaching out to anyone who has successfully mated an LS engine to an SM465 and divorced NP205. How did your conversion go? Did you go with a hydraulic clutch? Any lessons learned? Not sure if I'm getting over my head, but I am replacing my entire drivetrain with more modern components. I have gathered most of the major components, but am deciding whether to rebuild an aluminum block 5.3 vortec sitting in the corner of my workshop or go with a new LS3 engine.
    The 465 had a mechanical clutch. The stock M715 linkage could probably be made to work.
    I like hydraulic clutches and have made 3 different set ups work on 3 different M715’s. But, simple normally wins so if you can make the mechanical bits fit, go for it.
    What gear ratio axles are you going with? I ask because an overdrive really is nice for driving above 50 mph.
    Jan 2022
    The gear ratio will be 4.65:1.
    What size tires are you planning?
    Jan 2022
    I'll be running 37" tires.
