Results 1 to 10 of 19
Thread: Turn signal switch
    Default Turn signal switch
    Hi all, does anyone know where I can source a turn signal switch that mounts to the steering column with the wire harness that goes through the firewall to the blinker box? Mine crapped out, and I’m trying to keep it as original as possible.
    Which turn signal system do you have? The Spartan mechanical box or the 3 wire electronic version used since 1968.
    I Have Spartan Mechanical Box. Box is good signal switch is bad.
    Dont know if anyone has any of those anymore NOS...might check with Vintage Power Wagons in Fairfield Iowa...no promises though...might be able to find a used one somewhere...
    Worse case scenario, you can convert to the solid state type...not hard and still correct to the vehicle...both types came from the factory...
    Thank you, brut4c. I will vintage power wagons tomorrow and continue to look around, I know where there is an old M715 by the side of the road in Maine, I may poke my head in there. I definitely need turn signals, I’m not the fastest one on the road and people need to know my next move.
    Nov 2019
    North East Georgia
    Thank you, Nomad… are they hard to convert? Do I get rid of the blinker box? Electrical is not really my thing.
    Nov 2019
    North East Georgia
    your 7-pin harness should thread right to either of those. Right? The rest would depend on the state of your wiring, blinker box, etc. I rewired my truck and put in a fuse box.
    Rooster - Del.Date 1-68 3G2080
    I will try it, all wires are in good shape, thanks for the help
    Switching to the new system just takes an afternoon of total immersion in the wiring diagrams. You will be connecting wire F to wire 22 and such. I have done it to my M715 and my Gasser M35. (Don’t connect F to 22 unless you verify it is correct. I just wrote that off the top of my head.)
