Results 1 to 10 of 10
Thread: Dual transfer cases
    Jun 2020
    washington 98620 usa
    Default Dual transfer cases
    Ive been doing lots of research in changing out the np200 on my m715. Ive yet to zero down a solution. Im keeping my stock engine and transmission. What ive got in mind is getting a divorced drivers side ford np205 and putting it in the place of the original np200 while pushing it as close to the transmission as possible; and running a passenger side drop off of the first np205. In my mind this sounds sound and will sit in line for the original linkages. I will need to figure out something with the drive lines. I do not plan on this being an easy project and will require fabrication. My area of expertise is not in this type of fabrication but i feel im up to the challenge. Any input on other options i can look i to? Has any one else dont anything similar?
    What are your design goals? I ask because a stock M715 in low range 1st gear already has a pretty decent crawl ratio and will idle up and over most obstacles.
    If you really think a 4:1 transfer case low range is what you need. Then what about the Atlas from Advance Adaptors? 1 part that will do what your proposed 2 items will do.
    I’m just curious.
    Jun 2020
    I’m just curious.
    Goals? I like lots of shifters lol. Actually ive always wanted a snail slow vehicle. My grandfather had a scout that was so low (had a dual tcase set up) you could hop out take a long and then walk back and get back in.
    That works. Add a PTO to each 205 for front and rear winches to add 2 more shifters!
    Jun 2020
    So im not wrong in my idea? It does have soundness? Also as well as giving me a second low would it also give a second high? Or will it just be another true?
    Hi/Hi would still be 1:1. Low/Low would be 1.98/1.98.
    Be aware the cab floor is shaped around the stock transfer case location. You will have to modify it a good bit to fit a second one. Not impossible. Just a barrier.
    you can marry a np203 rangebox to a np205 and get 4:1 crawl ratio in a bulletproof single piece assembly.
    Is that what we picked up from Joe in Cleveland? I couldn’t remember what it was so I didn’t mention it in this thread. Thanks for throwing the correct numbers out.
    I think you have to get a Ford divorced NP203 to marry up to the NP205. At least that's my best recollection of a conversation with one of the old timers.
    Come and take it
    either a divorced or a married np203 range box mates to a circular pattern married np205 (not figure-8 pattern).
Tags for this Thread
