ARE there any stock headlights to be found? or direct replacement? I really dont want to go led.
any help is appreciated
Should be a standard 7" round. Same as most CJ Jeeps and Harleys.
If you need 24v:
https://memphisequipment.com/M715-1-...ght-p3532.html
They are standard 7 inch round...I put Hella dot legal ones on mine...just need to remove the waterproof connectors from the ends of the stock wires and splice on a new connector for the new light you choose.
Yep just the standard M-series 24v 7" headlight that is in most all M-series military trucks. They are readily available from most military vehicle parts dealers or on places like eBay.
Dave
Right...should have said that...
You can get the original lights and keep everything stock...you can also go to newer, brighter, halogen bulbs if you want...I assumed you were going with the new but we all know the problem with assuming...
