Stock tires are 34 inch...so 35's would be a bit less rpms at speed than stock and 33's, a bit more...both will fit and work as far as height...not knowing the width, I cant speak for that...
Not familiar with the Holley EFI...I do know the stock engine, between the military version and the civilian one, came with a Holley 1920 one barrel or a 2300 or 2415 2 barrel...the 2 barrels throttle plates cross sectional area is the same as the size of the intake manifold to head ports cross sectional area. That ends up equaling 350 cfm...so anything you use should be that size max...it just cant flow above that...unless you are using a turbo or supercharger to make pressure...I wouldn't recommend that on a stock motor though...efi, yes...forced induction, no.
