My first M715 and I picked it up from a fire department in West Plains, MO. Large liquid tank and pump in bed with plastic gas tank and fuel pump for truck. I'm trying to get it back to military parade level and need some help in what is original and what is Bubba. I'll try to post pics, but it will be my first attempt to do so, so I'll try to explain as well.
First...inverted tie downs on front outside of cargo bed, one in each forward corner. On trailers, these would hold a trailer electical cord, but I can't figure out what these two upside down tie downs secure.
2. Approximately 3" hole on passenger side of cargo bed between tool box lid and rear fender. I've seen a pic of another Kaiser with a second jerry can brakcket in that position, so I can't see if the hole is original or Buba. If original what was the purpose?
3. Bracket on dash in blank area where data plates are located. Sheet metal screwed into place with two sheet metal screws through dash. Approximately 4" open space at top and bottom and pretty solid steel, so holding something heavy. Bubba?
And, 4 ...just a pic of the truck as it sits undergoing clean up. If you see anything good, bad or ugly, now is the time to let me know.
Thanks in advance...
