Page 14 of 18 FirstFirst ... 456789101112131415161718 LastLast
Results 131 to 140 of 179
Thread: M724 across the Atlantic.
  1. #131
    I start the A again, it didn't have the right space.
    The diagram of my installation, circuit breaker and slave receptacle.
  2. #132
    The glass is cracked in the middle, it took me a while to realize.
    I will have to start over.
  3. #133
    Really nice, thanks for the pictures.
  4. #134
    The truck is looking great! I love the different 4-color camo paint you went with instead of the usual Woodland winter patern.
    You said "I drove it today, the brake system is not leaking but it is not still braking." Either the brakes are not adjusted correctly or you still have air in the system and need to bleed them some more. Or a combination of both. You may have to go through the system to make sure everything is working properly.
    Zone holster maker
  5. #135
    Nothing of the kind.
    I am waiting for new brake shoes, the existing ones are worn to the iron.
    I will also install a new NOS master cylinder, I like the original stock.
    From scratch, the brake system is a long rebuild.
    The photo below shows the correct fit and the wear in question.
  6. #136
    One word, "Nice".
  10. #140
    Out of four original shocks, two were still in very good condition, one front and one rear.
    After renovation and transformation they will be equal to be installed at the back.
