I'm going to need emergency brakes now, corp 14 bolt 13' backing plates, one ton? duallyor single wheel? anybody know what years thereabouts. Need ammo for scrounging. Thanks
I'm going to say 3/4t, the ones on my CUCV 14bolt are 14.25". Try 73 up.
what do you need? I might have it laying around or something.
Sounds right to me too...up until somewhere in the late 80's I think...
One member who did that reported he needed to slightly modify the bolt pattern and open the center hole up a little and then they worked real nice.
I am about to put rear disc on my M1009,and will have all of it including cables when I'm done.It is SW but has the big drums for the 13" shoes.
Thanks 1 ton, I'm defininatly needing them, I'll try to pm you. Dan
I'm sorry about the double reply, I guess I'm impatiant. I can't pm you 1 ton you're not in there nor am I. # 206 762 7110 Dan
They came with 10 blots,but I swapped in a 60 front and 14 bolt rear.
ahhhh
I keep thinking 12bolt rear, 10bolt front. Sheesh!
Yeah they stopped using 12 bolts in about 1980,give or take.These trucks in stock form are a turd,6.2 diesel with a auto and 10 bolts with 3:08 gears.
