Results 1 to 3 of 3
Thread: Stock gears in later model axles?
    Sep 2014
    Wichita Falls, TX
    Default Stock gears in later model axles?
    Just sold a transmission I won't be using and the buyer and I were talking about my truck, mentioned I'll be swapping the ring and pinion gears and he said he might be interested in my old gears for a rock crawler he has sitting in his barn.
    I know our stock axles are different from newer ones but don't know how different. If he found the right carriers could he put a set of our 5.87s in newer housings?
    In all the axle discussions I've read on here I don't think that has ever come up.
    The ring gear on ours needs a spacer to work on the newer ones...I remember that coming up several times before...the offset is different...
    Heres some info on this:
    Ring and pinion questions
    Sep 2014
    Wichita Falls, TX
    Well crap. Read that and realized the R&P set I was planning on buying from nolfy won't work on the rear. The one he has is the .625 offset.
    Hmmm....
