Results 1 to 7 of 7
Thread: Source for Knuckle Seals & Kingpin Bearings
    Default Source for Knuckle Seals & Kingpin Bearings
    I just stumbled across this information on BinderPlanet: Torque King 4x4 has a bearing & shim kit to fit Dana 60 closed knuckle axles, as well as a felt seal kit, and a grease apparently made for closed knuckle applications.
    Bearing & shim kit: QK4618
    Felt seal kit: QA4936
    Lubricant: 777
    http://www.torqueking.com
    Apologies if this information has been posted before.
    Just noticed they also stock the upper kingpin bronze bushings.
    Fort Smith, Arkansas
    Glad to have this information.
    Yeah really...great stuff...thanks for posting it!!
    Just repaying my debt, Jon-- I've gotten a lot of useful info around here.
    Default Torque king is great, but......
    I ordered the kit that was recommended for the Dana front end, the problem is, is there is a difference between the commercial Dana and the military Dana front end. The lower bearings and races are smaller and have a different taper in the military version. Just keep this in mind, when ordering. Be specific with Roy. He is very helpful and knowledgeable.
    Great follow up info...thank you!!
