Results 1 to 10 of 12
Thread: Dana 60 king pin
    Default Dana 60 king pin
    anyone up in the PNwet done a kingpin replacement ? or know someone/shop that can ? I am at aloss here, but I do know my truck is scary at bast to drive do to a ton of positive camber on the drivers front . any ideas would be helpfull .
    Fiend
    New Haven, CT
    The plastic inserts are very easy to replace. Are your lower bearings OK?
    I havent started tearing it apart as of yet , I dont know why but axels scare me . that is why I kinda wanted someone with alil knowledge to lead the way
    New Haven, CT
    Quote Originally Posted by Overfiend View Post
    Fiend
    What are the symptoms? Are we talking about a stock D60 or a kingpin one?
    stock but I am under the impression that this is a kingpin aswell (as per PO 2530-928-6159
    ARM AND KING PIN ASSEMBLY,
    RIGHT
    25730X (72447) in the manual pdf)
    I have positive camber on the drivers side and one hell of a death wobble
    Jun 2009
    Litchfield Illinois
    Did you swap this axle in your truck? If I remember correctly, the camber should be between 6-8 degrees. If it is more it can cause death wobble. You may need to shim between the springs and perches to make the adjustment. Check with a shop that does alignments and they can tell you what the camber should be. My axles came out of a Chevy 1028 military truck. I just gave the alignment mechanic the year and model and he told me the caster angle. There are also some good articles at Pirate 4X4's web site.
    it is the axle that came with the truck, closed knuckle Dana 60. so far all I have come up with is the lower kingpin is the adjustment point but I dont really know for sure. thank you for the advice ..
    Nov 2009
    Greenwood, Indiana
    Quote Originally Posted by Troop ISP View Post
    Did you swap this axle in your truck? If I remember correctly, the camber should be between 6-8 degrees. .
    I think you mean caster (angle to which the steering pivot axis is tilted forward or rearward from vertical), vs. camber (angle of the wheel relative to vertical, as viewed from the front of the front axle)
    6-8 sounds about right for caster. Less than 4 will almost definitely cause death wobble (along with loose steering parts). I think that the IH Scouts had near 0 caster. I'm not sure why they didnt have death wobble.
    Thanks, George
    Joshua 24:15
    Quote Originally Posted by Flingarrows View Post
    small tires
    1968 M715
    1968 M725
    Nov 2009
    Greenwood, Indiana
    Quote Originally Posted by defbob View Post
    small tires
    Makes sense
    Thanks, George
    Joshua 24:15
