Results 1 to 10 of 10
Thread: Decode 1967 230 Tornado Engine Code Number
    Default Decode 1967 230 Tornado Engine Code Number
    Hi everyone! Newbie here. Looked at a 1967 M715 and can't see enough of the engine code number to determine what the number is. I have searched several different ways on the forum and am unable to find anything that will help me. Is there a way to decode the engine code number? Thanks in advance.
    I really have no memory of anyone even asking if there was an engine number. Much less how to figure out what it means.
    You trying to determine if you have a matching numbers vehicle or narrow down the build date?
    Thanks for the reply Barrman. I am trying to record the engine code number. I believe the engine to be original, however because it has an engine number, I'm just trying to document it. The number as I can see it from my photos is: 30 M2 06 1275. The first few letter/numbers are hard to read.
    After doing research via my search engine, I may have more information: The engine code number may be 230-M2-06-1275. The "10" manual just shows a picture of the location of the number, not how it decodes.
    230= 230 ci?
    M2= unknown
    06-12= date?
    75= 7.5 compression ratio?
    Does this look close?
    I have seen this info somewhere...have to try to remember...
    I do remember the 75 is the compression ratio...7.5 in our case and 8.5 optional on the civvy version...I think I found the decoder in an old civvy manual...hope I still have it...
    A week ago I was looking at a 1967 MOTOR Manual. I wasn't sure it would have enough useful military info in it to make it worth buying. Should I have brought it home?
    Well I searched everywhere for my book and couldnt find it...then I figured I must have posted it somewhere...looking back through the archived versions of the former board setups we used, I finally found this...talk about a blast from the past:
    Date: Sun May 16, 1999 1:04am
    Subject: Serial # decoding
    Well, the engine numbers break down like this:
    230-----Cubic inch
    M-------Military
    3-------Year, 1 is
    1966, 2 is 67, 3 is 68, 4 is 69
    04------Month, in your case April
    02------Day, in your case the second day of April
    75------Compression ratio, 7.5:1
    There could be one or more letters between the Day and Compression ratio as shown below:
    S-------Service engine, don't know what that means exactly...
    R-------Short block
    B-------Oversize bores
    A-------Undersize crank and rod bearings
    If I remember right, with the oversize bores and the undersize crank and rod journals, a number was given as well to indicate the amount that these dimensions varied from stock specs...e.g. A10 would be a .010" undersize for the crank/rod bearings.
    Nice to bring this up to date!!
    So yours is a June 12th of 67 build date unit...how does that mate up with the VIN/Delivery Date?
    Anyone...anyone...Buehler....
