Results 1 to 3 of 3
Thread: Electric fuel pump
    Default Electric fuel pump
    Question for the big block chevy boys............... Whats a good electric fuel pump to feed my holley 750? Pressure regulator advised? Pressure setting?
    Sep 2014
    Wichita Falls, TX
    SBC here, but a carb is a carb.
    I'd always heard carbs don't like more than 6 or 6.5 psi. I'm running a cheapo Mr. Gasket fuel pump rated at 6 psi, no regulator.
    True...if you get much over 7 psi to a carb, the needle will be held off the seat and it will flood-o-matic all day long.
