Page 1 of 3 123 LastLast
Results 1 to 10 of 22
Thread: SBC air cleaner
    Default SBC air cleaner
    At the 2006 FE, PC gave me his carb intake and canister air filter from his truck since he wasn't going to use them.
    I have mounted them on my 350 with a quadrajet carb.
    That looks pretty good. Did you find an off the shelf filter to fit that housing like we talked about? Mid -'90's F-150 is kind of close I think.
    The stock filter was clean. Apparently PC never drove his truck much.
    I haven't tried to locate a replacement filter yet. One issue is that the stock filter has the vanes to swirl the incoming air to remove water, dust, etc. I want to maintain that function so that plastic piece would have to be saved somehow.
    Lindale, Texas
    that looks like the air filter housing on my massey furguson tractor. it's a 255 from the early 80's. my tractor that is.
    PC, got it off a helicopter. He can probably be more specific tomorrow.
    I was considering using an Airaid carburetor adaptor to adapt to the hood-mounted air cleaner. One item to figure out is the Airaid carburetor adaptor has a larger diameter inlet than the air cleaner. I will also need to find a good flexible hose to attach the two.
    http://www.airaidsales.com/AIRAID-Co...ke/airaid.html (The black snail shaped thing)
    Haven't started the fabrication yet, but I would like to adapt inside of the hood mounted air cleaner for a K&N or similar filter.
    What happened to the pictures in this post, Kwai?
    Oct 2008
    north florida
    Talking
    Quote Originally Posted by porkchop View Post
    Yeh, I wanna see!
    Jan 2007
    Fort Smith, Arkansas
    Me three!
    I didn't get a picture last weekend, but the housing was on the truck Kwai drove to the BMJP show. Let me describe it for you:
    Round, sitting on top of the carb with a wing nut holding down. A hose was attached to a stock M715 hood mounted air filter canister and another hose attached to the valve cover vent.
    That help?
    Sorry, couldn't resist.
  1. Air Cleaner for 2 Barrel Carb
    By rboltz in forum Modified Tech
    Last Post: February 6th, 2017, 02:47 AM
  2. hang down style air cleaner...
    By Wintermute in forum Open Discussion
    Last Post: April 9th, 2010, 03:30 PM
  3. Air Cleaner Installation help needed...
    By kyken in forum Open Discussion
    Last Post: February 19th, 2010, 09:25 AM
  4. Air cleaner question
    By Duane in forum Stock Tech
    Last Post: January 13th, 2009, 10:28 PM
  5. Air Cleaner
    By Mot-Man-616 in forum Stock Tech
    Last Post: August 21st, 2007, 09:26 AM
